Dr. Zuki
Home Gas Explosions: Preventive measures?
8 posts in this topic
Again the TV news runs a very scary piece about a gas explosion leveling a home in Clifton, NJ a few days back.
And there have been several in Queens with homes fully destroyed upon exploding.
Why are there so many of these explosions and can a homeowner take any preventive measures aside from leaving the premises after dialing 911 and opening all doors and windows???
It seems like there may be neglience on the part of the utility providers responding to these jobs too.
Maybe I never should have converted from oil heat to gas years back!!! LOL
But it really is tragic seeing these homes leveled like tornadoes hit them...
Dr. Zuki
Lawrence Hospital Center
Dr. Zuki
If you recall in the home gas explosion in Clifton, NJ, the homeowner evacuated the house then went back in and flipped on a light switch then everything went boom...
If you think there is a gas leak, just get yourself and all of the PEOPLE in your house out, and dont touch or use anything with power or heat or a spark or batteries etc just leave and call the fire department when you are safely away from your house....
here is a a link from the Ohio Public Utilities Commission regarding gas leak safety:
http://www.puco.ohio.gov/PUCO/Consumer/Information.cfm?id=5812
Edited by bvfdjc316
One solution is the all-electric home
Since many homes are equipped with cordless phones and many elderly use the secondary bells and light flashers one would wonder if even asking dispatch to try the call back number could be enough to set off an explosive event.
Just like most elementary kids are taught/know from fire prevention...
Get out, and STAY OUT!!!!!!
If we take a call for an odor of gas we tell them to evacuate.
If you tell them to turn out a light, that spark could trigger an explosion.
If you tell them to open the windows, you could be letting out some gas that was above the UEL and now it lowers into it's explosive range.
Perhaps units such as these could help:
First Alert Explosive Gas Detector
PEMO3 likes this
On the same note lets make sure we do not cause the explosion. It's easy to become complacant on gas leaks since 95% are not serious i.e. defective stove, burner left on.
Only use intrinsically safe equipment. Leave the TIC on the rig because it's not intrinsically safe. Don't ring the doorbell or turn on light switches. Turn your handlight on out side.
We investigate with two seperate meters. A TIFF (orange meter used by most utilities) pretty sensitive good for locating the source of most leaks. The second meter for most trucks is an ALtair which provides a percent of the LEL reading. This allows you to know when your dealing with a minor or serious leak.
One thing to remember is the meters the utility crew uses measure the concentration of gas in the air. It is not uncommon for our members to be assiting a utility crew check basements or gain access. Gas workers are for all intensive purposes deal with gas leaks every day and may not treat the situation with the urgency we feel is necessary. This is all important because a reading of 5% on the utility workers meter is the equivalent of 100% of the LEL. It means the environment is explosive.
First alert Explosive Gas Detector
Great find. A search of the internet found this item available at Lowes for $60. Home Depot has another brand for the same price. Small price for peace of mind!!
